Access violation error when pressing escape in Statistics window
vertigo
Post by vertigo »
Title says it all. Example error:
Access violation at address 000000000040BFC5 in module 'HxD.exe'. Read of address 0000000000000000.
Seems to be the same regardless of which file(s) loaded. Doesn't cause HxD to crash, I just hit ok and carry on.
W10x64, HxD 2.5.0.0
Re: Access violation error when pressing escape in Statistics window
Thanks for the bug report. Fixed in the current development build.
DVV
Access violation when pressing Esc in Statistics
Post by DVV »
HxD ver. 2.5.0.0, reproducable with both 32-bit and 64-bit version.
Steps to reproduce:
1. Open any file in HxD
2. From the main menu, select Analysis -> Statistics
3. In the Statastics view, press Esc on the keyboard
The result:
HxD
Access violation at address 000000000040BFC5 in module 'HxD64.exe'. Read of address 0000000000000000.
ОК
Re: Access violation when pressing Esc in Statistics
Seems to be a duplicate of this report: https://forum.mh-nexus.de/viewtopic.php?f=3&t=1181
DVV
Post by DVV »
Could you remind me where I might download an updated English version of HxD which has this error fixed?
DVV
Post by DVV »
DVV wrote: 26 Feb 2024 18:42 Could you remind me where I might download an updated English version of HxD which has this error fixed?
Sorry, is there a newer version of HxD executable where this error has been fixed?
(To me, it would make sense to release a bug-fixing version, e.g. "2.5.1", that would contain all the bug-fixes that have been identified and resolved since the version 2.5.0.)
Not available currently, but I'll look into it.
