A binary file often has fill bytes, such as xFF, that go on indefinitely. It is desirable to be able to skip over them to the next significant part of the file. Being able to search for NOT <hex string> would be very useful, and would seem to be just as fast as searching for the same length string.
Thank you for your great program.
Search for NOT <hex string>
Re: Search for NOT <hex string>
I second that request as well as the Thank You part.
This is one feature that I really miss.
deve loper
Hi. Really like HxD. Would love the search not option.
Best, Deve.
Best, Deve.
That's a really useful feature in some cases!
