Hi! I want to edit file "pakchunk10-WindowsClient.ucas". This file is from the Fortnite game.
So i open Fortnite > open HxD > open file pakchunk10 > edit hex code > and here error appears.
How can i bypasss this thing so i can save edited hex code when Fortnite is running?
Cannot open file for write access. Used by another process.
Re: Cannot open file for write access. Used by another process.
Ideally you would ask the one who made the tutorial.
Where do you enter it (which colum hex or text?) and what is the error message?> edit hex code > and here error appears
UPDATE: Now Fortnite added new update, where when you edit any of .ucas files in game folder by hxd, it detects it and kicks immediatly after couple seconds of game saying u have to verify game files. Right now im on some discord and i can see guys streaming playing normal match when using HxD tweaks.
My question is how to change hex codes of Fortnite without it seeing that i've edited something.
