Already Implemented: HxD: Live adaptation to window width
Bryan
Post by Bryan »
It would be nice if the window refreshed while it was being resized with Adapt to window width enabled.
This way I would know when to release the mouse button.
In my version it works: Do you press the button on the toolbar/choose the option in the view-menu or do you use the options-dialog?
I think this is a confusion about the options-dialog:
The options in the View-tab only apply to new windows, the old ones are left unchanged.
This is because on the toolbar and in the view menu you can set these options for every window individually and you probably don't want these to be changed because you've set default options in the Options-dialog.
Bryan
Post by Bryan »
My mistake, I had the Windows option "Show window contents while dragging" unselected.
With this option enabled, the Adapt function works.
Sorry to waste your time.
Ah, okay.
Thanks, for telling me.
