How Do You Earn the Hellfire Torch in Diablo 4 Season 15?
Ephraim
Post by Ephraim »
The Hellfire Torch, the most highly sought-after Mythic Unique Charm in Diablo 4 Season 15, carries on the legendary status of the classic Hellfire Torch from Diablo 2. It has become a core item that every end-game build strives to acquire this season.
This accessory provides a percentage-based boost to all attributes and elemental resistances, grants up to +4 to all skills, and unlocks an additional equipment slot specifically for a Unique Charm. It also includes a set-bonus counter, significantly lowering the requirements for completing gear sets.
To obtain this powerful item, players must complete a series of hidden prerequisite quests, collect Prime Evil Splinters, and gain access to the Echo of Tristram - a challenge that pits you against the three Prime Evils.
The First Step: Acquiring the Torch
Collect all 10 of Deckard's Journals to unlock the hidden Old Tristram area. These journals are scattered across various landmarks throughout Sanctuary, typically found near Waypoints. Once you have collected all of them, you gain access to "Deckard's Memory." This prerequisite quest only needs to be completed once; you do not need to collect the journals again for subsequent runs.
After Completing the Prerequisites
Farm three types of "Prime Evil Splinters": the Splinter of Terror, the Splinter of Destruction, and the Splinter of Hatred. These shards drop exclusively in three seasonal dungeons - corresponding to the Echoes of Diablo, Baal, and Mephisto - at Torment X difficulty or higher. Since the drop rate is not 100%, you may need to run these dungeons multiple times to collect all three.
Once You Have All Three Shards
Open the Horadric Cube and transmute the three shards to create "Wirt's Lucky Coin." This item serves as the sole key to opening the red portal to the "Echo of Tristram." Take Wirt's Lucky Coin to the fountain in the center of Old Tristram and toss it in to open a portal to the "Pandemonium Event."
Upon entering the red portal, you will face the Echoes of Diablo, Baal, and Mephisto simultaneously. This is a highly difficult encounter; the three bosses will coordinate their attacks, unleashing abilities that cover a wide area. It is strongly recommended to tackle this challenge as part of a group. Defeating all three bosses will yield loot, including the coveted Hellfire Torch. Be aware that there is an internal cooldown on drops; you must wait 20 minutes between kills.
Summary
Repeatedly farming fragments and challenging the "Red Portal" bosses consumes a significant amount of potions, repair materials, and gear durability - the costs add up over time. Since Diablo 4 gold is the primary universal currency, maintaining a healthy reserve ensures you can keep running these encounters without having to pause for gold-farming sessions.
Many players choose to form groups and rotate portal keys. One player uses a "Wirt's Lucky Coin" to open the portal, and every member of the party receives their own individual loot drops. This approach shares the burden of farming fragments and makes obtaining the Hellfire Torch much more efficient.
If you'd rather skip the tedious grind of farming dungeons for fragments or rolling for the perfect stats, you can simply buy Diablo 4 items to acquire a best-in-slot (BiS) amulet immediately.
Many players run these encounters repeatedly, aiming for a Hellfire Torch with perfect stats. Because the affixes are randomly generated, securing a version with high "All Stats" percentages and maximum "+All Skills" bonuses often requires clearing the "Echo of Tristram" multiple times.
Each attempt requires portal materials, and your gear's power level determines whether you can survive the combined onslaught of the three bosses. If your current equipment isn't up to the task, you can acquire specific D4 items to bolster your build - adjusting your defenses, resistances, and damage output to increase your chances of success.
Ultimately, the Hellfire Torch is a key endgame objective in Diablo 4 Season 15. This hidden content offers both a hit of nostalgia and exceptional gear power, making it highly engaging whether you tackle it solo or as part of a group.
