Fixed: Checksum calculation feature visibility problem
snovotill
Post by snovotill »
Hi, when you calculate a checksum after installing the program, the output is not visible because the Result pane is collapsed all the way down.
It took me 20 minutes to figure out that I can pull the pane up to see the calculated values beneath. The installer should not default a fully collapsed pane. Probably an easy fix?
Re: Checksum calculation feature visibility problem
It came from a resize while designing that went unnoticed, since the settings where different in the local INI file. Thanks for reporting.
Fixed in the development version.
Fix included in 2.3, released today.
