Comparing does not respect the selection
mekatum
Post by mekatum »
Hi all!
I select some data in first window, select some data in second window and I want compare this selected data. I try Analysis -> Data comparison -> Scope "Selected data", but HxD compare both files completely, not only selected data.
It's a bug or feature?
Any way, thanks you for your work!
Re: Compare selected data does not work
It should respect the selected region, so it's a bug.
