I was playing Digimon world 3 on epsxe, and as i was saving my game i accidentally pressed esc key cosingthe game.
When i try to load my game it says the file could not be accessed.
At first i got sad and cursed myself on how dumb i was, but then i started to look for ways to repair it and found Hxd, the problem is that even after trying to read and learn how to alter saved files i cant seem to work out a way to solve my problem.
So now i come here to ask for help so i can get my over 24 hs of play.
Thanks a lot.
(I´m leaving a copy of my memory card file in case anyone knows how to solve it quickly)
Help with repairing saved game
Request to fix memory card
- Attachments
- epsxe000.7z
- memorycard
- (2.42 KiB) Downloaded 2959 times
Thanks a lot.
Thanks a lot.
Repairing saved games
Thanks a lot.
Thanks a lot.
Re: Help with repairing saved game
I merged your three topics, since they are all about the same, and moved it to support, since you are asking for help.
Regarding your issue, I don't know anything about the save game file format of your game. You might have some luck in the support forum for the game, or in a modders forum for Digimon.
