Add additional checksum algorithms
Fireboyd78
Post by Fireboyd78 »
HxD is starting to come together nicely! Great work so far on HxD 2.2! :D
I'd like to request some additional checksum algorithms that are commonly used. These include, but are not limited to:
  • Jenkins-One-At-A-Time (JOAAT)
  • CRC64
  • FNV-1a (32-bit & 64-bit)
With the potential addition of CRC64, it may be necessary to rename "Custom CRC" to "Custom CRC32" and add a "Custom CRC64" option.
If you do consider this request, please at least add FNV-1a -- the algorithm itself is incredibly simple yet effective.
Thank you!
cghult
Re: Add additional checksum algorithms
Post by cghult »
I am trying to use the HxD for modifying Serial Presence Detect EEPROM files for DIMMs. The CRC algorithm used is CRC-16/XMODEM or CRC-16 CCITT (XMODEM). Can this be added as one of the CRC options?
You can use the custom CRC function and search for the polynom and other settings on Wikipedia.
