Enter key does not work at Block Select (CTRL-E)
plutomaniac
Post by plutomaniac » 20 Jul 2019 21:44
At the latest HxD v2.3.0.0 under Windows 10 1803, it is no longer possible to press the enter key to select a block. To reproduce, press CTRL-E, change Length to any value larger than the default 1 and press Enter key. It will only select one byte. Pressing the OK button does still work.
imadewins
Re: Enter key does not work at Block Select (CTRL-E)
Post by imadewins » 16 Nov 2019 21:02
+1 This does happen after the update to 2.3.0. Can confirm it doesn't exist prior.
