Upgrade from 1.7.7.0 to 2.4
User avatar
prino
Post by prino »
Being a great fan of the "if it ain't broke, don't fix it rule", I'm still using HxD 1.7.7.0, installed in "C:\Program Files (x86)\HxD", and it does everything it needs to do, which for me isn't that much, I almost exclusively use it to edit IBM z/OS created XMIT files (encoded in EBCDIC), and occasionally I use it to insert spaces between consecutive CR/LF's when they've been stripped by the editor I normally use.
So simple question, what would be the advantages of going to 2.4, and what would be the best way? Install or portable?
Robert AH Prins
https://prino.neocities.org/zOS/zOS-Tools.html - Some programming here :mrgreen:
Re: Upgrade from 1.7.7.0 to 2.4
The change log lists all the relevant changes since, version 1.7.7.0.
https://mh-nexus.de/en/hxd/changelog.php#v_2.4.0.0
The installable version has the advantage that you can integrate it in the context menu.
