Edit -> Select Block... (Ctrl+E)
mukke
Post by mukke »
Hello Maël,
I'd like to request a little change in the 'Select block' window: the possibility to set 'End-offset' and 'Length' to be able to, well, select a block of fixed length in first instance. :roll:
Thank You for that awesome program and considering this request,
kind regards
Re: Edit -> Select Block... (Ctrl+E)
I don't understand what you mean. What's wrong with the way it works now? Please give an example.
I suppose you mean selecting backwards, i.e., set the start offset, then select x bytes before that.
This could be achieved by allowing negative numbers for Length.
Again, please give an example for the numbers of end-offset and length and what behavior you would expect.
mukke
Post by mukke »
Hello Maël,
sorry answering that late.. (been busy with examination last couple of month and totally forgot about this..)
yes, selecting backwards is what i want to do and negative numbers for length would accomplish exactly that
an example: microcode tinkering with AWARD BIOS
open BIOS.BIN
search: *ALIN16* -> Byte before first asterisk is end-offset
next 8 Byte give length of block (little endian)
so i have/know:
3. Length of block
2. End-offset==(offset_of_*ALIN16*)-1
press ctrl+e to select block
BUT have to calculate 1. required Start-offset by myself
see attached screenshot (might be better easier to understand then my kauderwelsh)
once again, kind regards
