Done: HxD: Full path visible
Bryan
Post by Bryan » 14 May 2007 21:04
I have multiple files with the same name in different paths.
In HxD, I'd like an option to see the full file path. This could be either in the window title, the status bar or anywhere that allows easy differentiation between files.
Many thanks, keep up the good work!
Bryan
Post by Maël » 22 May 2007 14:42
I'll place the full file name in the window title and display it when moving the mouse above the tabs using tooltips. The tabs will show the file name without path (as they do now).
Post by Maël » 08 Jun 2007 23:43
Implemented in version 1.7.1 beta
