Undo&fill selection for large amounts of data (entire disks)
kubsztal
Post by kubsztal »
I got this error when I tried to fill 2GB SD card with zeros (open as physical disc/select all/fill selection). RAM was consumed in ca. 98% and card was supposed to be filled in ca. 70% (I didn't write the changes).
Regards, Kubsztal.
Re: Out of memory error
Hi Kubsztal,
This isn't really a bug. The reason is as you said that there isn't any free RAM left. That's because for the undo-operation data is stored into RAM, in this case the whole 2GB sd card.
A direct mode or limited undo would be the solution. So I move that to Enhancement requests and renamed it "Undo&fill selection for large amounts of data (entire disks)".
Re: Undo&fill selection for large amounts of data (entire disks)
BTW, currently the only solution is to fill ony the first half of your card save the changes, then fill the second part and again save the changes.
kubsztal
Post by kubsztal »
Dirrect access would be a good solution in my opinion. Also maybe pagefile/virtual memory could be used for undo purposes or even simple hidden file if there is enough space on one of partitions. Keep up the good work!
asmix
Memory leak
Post by asmix »
Filling all HDD space with zeros use all free memory and then crash.
Re: Memory leak
All edit functions including filling a hard disk are limited by the amount of free RAM. There will be "immediate" function in future to address this problem.
Does it really crash, or just say out of memory? If it crashed could you please give details on what happens and how that crash manifests?
g4qber
insert bytes
Post by g4qber »
1. ctrl N
2. edit, insert bytes
3. dec 5 000 000 000 (Edit: on my machine dec 9000000000)
get
"Assertion fehlges"
compare with
1. ctrl N
3. dec 2 000 000 000
get
"Out of memory"
1. ctrl N
3. dec 3 000 000 000
get
"Access violation"
Edited for documentation purposes.
asmix
Re: Memory leak
Post by asmix »
Sorry for long time answer.
Program crashed only once and i can't reproduce this crash again. Maybe some strange circumstaces.
As you say earlier program write message "Out of memory".
That's all.
P.S. I'll find error message that caused a crash, it's third screenshot in this topic http://forum.mh-nexus.de/viewtopic.php?f=3&t=288, but i guess there are some other numbers.
Re: insert bytes
See also bug-tracker item #158.
