Spinedit for bytes in row
CrytoGen
Post by CrytoGen »
I often use Hex Viewers for view device data flow. Usually it contatins some header (for example 0xFFFFFFFF).
I need pick up bytes in row, and spinedit is comfortably for inc/dec bytes in row.
And superiorly would function for automaticaly calculate bytes in row for some header.
P.S. Sorry for my bad English :oops:
Re: Spinedit for bytes in row
What exactly should the spinedit do? Is it to modify the data or the actual position?
Please explain what you want in more detail.
g3gg0
Post by g3gg0 »
i think he means to have a "spin control" to select how many bytes are displayed in one row.
default is 16 bytes per row. he wants to easily change that with a spin control :)
CrytoGen
Post by CrytoGen »
Yes. I want select "How many bytes in row" with step - 1 byte :)
It's only possible to either have a combobox or a spinedit. It's good to be able to quickly select common sizes (combobox) so I am inclined to keep it. Why do you need to increment in steps of 1, and why don't you just enter the number?
