Page 1 of 1
Fixed: Garbadge display on more then 32 bytes per row
Posted: 06 Oct 2009 02:01
by smeezekitty
i attached a picture::::
Re: Garbadge display on more then 32 bytes per row
Posted: 09 Oct 2009 07:03
by smeezekitty
Hello Mael,
my os is windows vista SP 1
its regardless of the graphics driver or file loaded it looks distorded
i think u will agree from da pictre above
Posted: 09 Oct 2009 20:21
by Maël
What version of HxD are you using?
Posted: 09 Oct 2009 23:58
by smeezekitty
1.7.6
Posted: 10 Oct 2009 00:05
by Maël
The newest version which is out since April is 1.7.7. This version should have this bug fixed.
Posted: 10 Oct 2009 00:32
by smeezekitty
its fine in the new version
Posted: 10 Oct 2009 01:01
by Maël
Please, check the new version before posting a bug in future. It reduces the time I spend trying to reproduce a bug.
Re: Fixed: Garbadge display on more then 32 bytes per row
Posted: 10 Oct 2009 02:54
by smeezekitty
it also fixed the ext2 stream read error
