HEX change and replace
User avatar
prino
Post by prino »
Can you look into making the option more user-friendly by allowing the specification of mixed strings, i.e. something like 'hh hh hh hh'x+'ASCII' (where the '+' is a user specifiable character) would be even more useful.
Robert AH Prins
https://prino.neocities.org/zOS/zOS-Tools.html - Some programming here :mrgreen:
Re: HEX change and replace
There will be support for regex in future version, see other feature requests in this forum.
User avatar
prino
Post by prino »
Maël wrote:There will be support for regex in future version, see other feature requests in this forum.
It's not regex I'm after, its really hex+ASCII, which is used to work on Pascal strings and certain EBCDIC in files I work with, and where I need to change both the length and content of the string, including it's length field.
Robert AH Prins
But that's what you are going to get :-p
To search for a text that you would express in Pascal like this,
'Some Text '#$76#$89' and some more'
you could write the following regex:
Some Text \x76\x89 and some more
