BreakLine on an End of a Line
omata
Post by omata »
File: SynEdit.pas
procedure TCustomSynEdit.ExecuteCommand(Command: TSynEditorCommand; AChar: WideChar; Data: pointer);
      ecLineBreak:
              if Command = ecLineBreak then
              begin
                InternalCaretXY := BufferCoord(1, CaretY +1); // <-- is new
                if SpaceCount2 > 0 then
                begin
                  SpaceBuffer := Copy(Lines[BackCounter], 1, SpaceCount2);
//                  InternalCaretXY := BufferCoord(1, CaretY +1); // <-- kill this
                  for i := 1 to Length(SpaceBuffer) do
                    if SpaceBuffer[i] = #9 then
                      CommandProcessor(ecTab, #0, nil)
                    else
                      CommandProcessor(ecChar, SpaceBuffer[i], nil);
                end;
              end;
Re: BreakLine on an End of a Line
This forum is not the place to talk about SynEdit. Please use the bug-tracker. SynEdit isn't my personal, but a community project.
omata
Post by omata »
I'm sorry.
Please delete my account.
arcostasi
Post by arcostasi »
thanks omata, your code works fine! Please continues in the forum, you helped a lot! :D
