Fixed: Disk editor in HxD prerelease - wrong disk size values
zeromido
Post by zeromido »
I just noticed that HxD 2.0 prerelease displays all logical disks' sizes as the physical disk size:
In the prerelease all logical disks' sizes are -1
And since you're already updating the disk editor I didn't want to create a bug report. So, this is just a heads-up in case you didn't notice :)
Re: Toolbars lock
The disk editor shows wrong values in the pre-release, yes, since I am working on it.
Please make a new topic in future, to keep it easier to manage, even if it's just a comment/heads-up.
zeromido
Re: Known issue: Disk editor in HxD prerelease - wrong disk size values
Post by zeromido »
OK, I will. And good luck :)
Should be fixed now.
