Fixed: Issue remembering window size at multiple inputs
plutomaniac
Post by plutomaniac » 04 Oct 2018 22:47
HxD does not seem to remember the window size when opening more than 1 file at a time via the context menu. In such case, the sidebars also have wrong proportions and appear even at small (i.e. 1 byte) files. The problem seems to affect the current pre-release HxD v2.1 version only. Encountered at Windows 10 x64.
Re: Issue remembering window size at multiple inputs
Post by Maël » 04 Oct 2018 23:00
It turns out this is a Delphi/VCL bug, and the fix I made triggers another VCL bug.
Will be fun to trace down :D
plutomaniac
Post by plutomaniac » 14 Dec 2018 15:31
Are there any news on this issue?
Post by Maël » 14 Dec 2018 15:49
Nope, this is a complex bug as mentioned and I have many other things to do. I'll post here when things change.
Post by Maël » 22 Dec 2018 22:38
Can you please test if this fixes the error:
https://mh-nexus.de/downloads/HxDPreRelease.zip
Make sure to register the Explorer context menu (through the options window) with one of the exe files from the ZIP instead of the older ones installed in your system.
plutomaniac
Post by plutomaniac » 23 Dec 2018 00:40
Yes, I can confirm that this build fixes the issue. It remembers the last window size.
Post by Maël » 17 Jan 2019 00:13
