Fixed: Custom CRC triggers Range Check Error
thfisher
Post by thfisher » 08 Nov 2018 15:25
I recently upgraded to version 2.1.0.0 of HxD. It is a wonderful program...thank you for maintaining it.
I did run into a small bug with the Custom CRC feature triggering a Range Check Error when exiting the program.
To replicate:
Start HxD
Open file
Select Analysis/Checksums...
Click the Custom CRC... button
Enter a Polynomial: of 4C11DB7
Enter an Initial Value: of FFFFFFFF
Click OK to close the Custom CRC settings dialog
Click Cancel to close the Generate checksums dialog
Close HxD
I've tried it on 3 separate computers and the Range Check error occurs on all 3.
Re: Custom CRC triggers Range Check Error
Post by Maël » 09 Nov 2018 06:50
Thanks. Fixed in the current build. I'll update this post once the new version is out.
Post by Maël » 17 Jan 2019 00:14
