Fixed: Garbage when copying from hex panel in some files
lordcanty
Post by lordcanty »
Rarely for some files, when copying certain bytes extra garbage is also copied. For every 0x04 bytes the 2nd byte will copy "NNpyin", and the 3rd "NNpy", and the 2nd+3rd "NNNNin".
I'm not sure why only some files cause this but I've attached one where it happens consistently (after uncompressing but also compressed). May be related to file size? Doesn't happen when copying from the text panel though.
Tested in 2.1 but the bug also exists in previous HxD versions.
weird.zip
(297 Bytes) Downloaded 2511 times
Re: Garbage when copying from hex panel in some files
I can reproduce it. For it to happen byte group size needs to be 4 or larger.
Fixed in current development version.
