Page 1 of 1
Fixed: Garbage when copying from hex panel in some files
Posted: 25 Nov 2018 11:34
by lordcanty
Rarely for some files, when copying certain bytes extra garbage is also copied. For every 0x04 bytes the 2nd byte will copy "NNpyin", and the 3rd "NNpy", and the 2nd+3rd "NNNNin".
I'm not sure why only some files cause this but I've attached one where it happens consistently (after uncompressing but also compressed). May be related to file size? Doesn't happen when copying from the text panel though.
Tested in 2.1 but the bug also exists in previous HxD versions.
Re: Garbage when copying from hex panel in some files
Posted: 22 Dec 2018 17:11
by Maël
I can reproduce it. For it to happen byte group size needs to be 4 or larger.
Posted: 22 Dec 2018 19:45
by Maël
Fixed in current development version.
Posted: 17 Jan 2019 00:13
by Maël
